Announcements
siemens 840d post
CreativeComposites123
siemens 840d post
Hi, does anyone know how to edit the siemens 840d post processor to force output of all tool vectors XYZAC and avoid using the cycle800 macro?
Thanks in advance
Arun.rs
Hi @CreativeComposites123
You can disable the CYCLE800 by setting 'var useMultiAxisFeatures = false'
var useMultiAxisFeatures = false;
Regards
Arun.RS
Technical Consultant - Post Processor
Yes , this would be a work around but if you disable the cycle800 which I have and then post the program, all toolpaths with tilt and turn will be affected. which wont work
