Announcements
Shortcut for switching workspaces
infoXNDBJ
infoXNDBJ
Manual entry
Shortcuts for switching workspaces
You can now switch workspaces with Ctrl+[ and Ctrl+] key combos. This will take you through the next and previous workspace in the order it is listed in the workspace switcher.
Can anyone explain meaning, please?
We want to switch quickly between "design" and "machining" workspace. From manual I understand
Ctrl + (nothing happens)
Ctrl+ arrows (nothing happens)
Ctrl + pageDown or Up (nothing happens)
jeff_strater
I just tried this on a Mac.  CMD + [  switches from Design to Manufacture, and CMD + ] switches from Manufacture to Design.  I don't have immediate access to a Windows machine, but I suspect that CTRL + [ and CTRL + ] would work the same there.
Jeff Strater
Engineering Director
jhackney1972
Affirmative, Ctrl +[ and Ctrl +] toggle between the Design Environment and the Manufacturing Environment on a Windows based Fusion 360 application.
Edit: Depending on the sequence you press the key combination, you will go from the Design Environment into the Simulation or the Generative Design Environment.
John Hackney, Retired
