Announcements
Shift + Click no longer works
rossowilliams
rossowilliams
I've used F360 for several years and a couple of computers, and I've always been able to hit the shift key to pan, and shift  click the center mouse wheel to orbit. As of the last update, I that doesn't work anymore. I've tried resetting the Pan Zoom Orbit shortcuts in F360 preferences, but that didn't work.
I'm running a Mac Mini M2 Pro with 16 gb ram and Sonoma 14.1.2. It was working really well until about two updates ago. I was on Fusion build 2.0.18441, and just updated to the latest build today, but still have the same problem.
I've searched, and it doesn't seem to be a common problem. I've tried the solutions I found, but no luck.
Is there any way to revert to a prior build?  Thank you for your help.
CGBenner
@rossowilliams
Welcome to the forum!
Can you share some information on the mouse you are using?  Are all drivers up to date?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
rossowilliams
The mouse is a Jellycomb WGSB-009C.
I'm on a mac, so there are no mouse drivers. I found a reply somewhere in the Autodesk forums with a mouse testing utility, and the mouse seems to be working fine.
Thank you for checking into this!
gugarcia11
I was having the same issue and it turned out to be the graphics settings. Under General Preferences, change the graphics driver to "DirectX9". Mine was set to auto and after changing it, everything seems to work; hopefully it works for you!
rossowilliams
Thank you for the idea. My driver selection is different. (Mac) I have Auto and Open GL Core Profile. It was set on Auto to start with. I changed it, but got no result.
rossowilliams
Shift Click is working again! This may have occured after installing the last build yesterday. Not quite sure. Productivity returns!
