SheetMetal - Flange Creation fails with UNDEFINED ERROR
As shown in the screencast, I get the message "UNDEFINED ERROR".
The Message "UNDEFINED ERROR" does not help a lot.
I don't have a clue what is wrong.
Can you please improve that error message?
Replies (7)
pawel.potyrala
Autodesk Support
Autodesk Support
Hi @Anonymous,
thanks for posting and sharing the screencast!
Would you be able to send me a link to the design? I would like to test it to figure out why the flange creation is failing.
If you do not want to post it here, you can send it to me in a private message. Thanks!
Best regards,
Paweł Potyrała
Technical Support Manager
Global Product Support
My Screencasts | Fusion 360 Webinars
Hi Paweł,
I can share the design, its attached to this post.
Thanks for your effort.
TheCADWhisperer
I was able to get this hybrid modeling technique to work.
Thank, that looks good!
It generates a nice flat panel 🙂
Where do I find that extrude(?) command you used? Is it the regular extrude? If yes, how do I select single lines instead of a closed contour?
TheCADWhisperer
In the Surface Modeling tools.
Your entire part could have been simplified a bit, but I just used what you presented.
HughesTooling
Here's another way creating 4 flanges then combine.
Mark
Mark Hughes
Owner, Hughes Tooling
pawel.potyrala
Autodesk Support
Autodesk Support
Hi @Anonymous,
thank you once again for reporting this. I reached out to our developers with a request to change the produced error message to be more specific.
@HughesTooling @TheCADWhisperer thank you for providing the workarounds!
Best regards,
Paweł Potyrała
