Sheet Metal
rgSCV3X
Sheet Metal
rgSCV3X
Good morning, if you import a file in STEP with all the sharp edges, is it possible to convert it to sheet metal and automatically create the folds where there are sharp edges?
Replies (7)
jhackney1972
Yes, but on this model why would you want to.  It is very small with a wall thickness of .001 inches.  You have to split the corners so the sides can fold down and then add fillets to the bottom to side edges.  Model is attached with the Flat Pattern developed in it.
John Hackney, Retired
TheCADWhisperer
@rgSCV3X
It would be faster to create from scratch - but Attached is your converted STEP file...
TheCADWhisperer
Units are Meters.
The wall thickness is 1mm.
In your example - the cuts are not perpendicular to the flat.
This can be verified in Wireframe view mode of the Flat Pattern.
My example...
rgSCV3X
Hello, could you send me a video to see how it was converted with the creation of the spokes?
Best Regards
rgSCV3X
Ciao, potresti mandarmi un video per vedere come è stato convertito con la realizzazione dei raggi?
Distinti saluti
TheCADWhisperer
Best Regards
@rgSCV3X
Everything is recorded in the Timeline.
How much experience/training do you have with Fusion?
rgSCV3X
Hello, thanks I was able to see, problem solved
