Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Dear Fusion 360 - My sheet metal part has a cutout, with rounded edges, which is created by projecting geometry. The geometry is good and the flat pattern looks good, however the DXF export does not render the rounds correctly. They are rotated and disconnected, see pics.
Solved by hanumara. Go to Solution.
Solved by HughesTooling. Go to Solution.
Do you get different results when selecting the poly line option? What view software? Can you share your dxf?
Sadly, I did test the polyline option, but the result was the same. And I have viewed the DXF in Autodesk's TrueView 2023 as well as Solid Works. I can't distribute the DXF.
OK> What happens when you import the dxf into a fresh Fusion 360 Document?
Ok I suspect the rectangular penetraion may not have been via a fully constrained sketch?...Not that that should be an issue..It's a bit hard to diagnose with the apparent NDA But Id start by creating the penetration as a quadrilateral and filet the Body.
Try creating a 2d drawing of the part and export as a DXF.
Mark Hughes
Owner, Hughes Tooling
Have you updated Fusion today? There is an update that might have some fixes.
Mark Hughes
Good Morning Mark & Warming Up,
While I abhor sketches with unconstrained points, I'm guilty of this transgression occasionally. The idea of filleting the body is a good one and I was getting ready to poke at the part from which this feature was projected and then the update pushed. Presto, the problem is gone! (I was ready with the 2D drawing work around, but "fixes" make engineers nervous.) What a strange error, but this is just in time as I push out a bunch of sheet metal parts.
Thank you both of your care and speedy responses,
Nevan
