Sheet Metal Rule-Popup-Window does not allow the viewer to see crucial Rule Info
ecnels
ecnels
When creating a sheet metal flange from a sketch,  The Flange Popup Window appears with various Sheet Metal Rules; however, the Select List at the bottom right of that Flange Popup Window is "cut-off" from the Users view so the actual thickness of various Sheet Metal Rules is not visible.  This "cutoff" data is essential to picking the User-Desired Sheet Metal Rule in order to produce the correct Flange.
Moving the Sheet Metal Rule Select-List underneath of the Sheet Metal Rule Text Box would greatly help and also eliminate a large amount of wasted screen blank space or otherwise allow horizontal and perhaps vertical scrolling in the Flange Popup Window (though that's less efficient, because it forces the user to scroll.  Presumably, the necessary screen real-estate needed to display the full Flange Window is known before that window is displayed; if so, that would help to display the size correctly, in order for the user to simply "see, select, and move forward".
I'm facing the same issue. Any resolution foreseen?
jhackney1972
Take a look at the Screencast on how to resize the dialog box you referenced in the original post.
John Hackney, Retired
Thanks a lot for you support John!
It works well but it's not so "intuitive" to have to find this secret green bar! 🙂
Issue solved for me!
Best regards.
