Greetings,
I've created a sheet metal component, and added aluminum rule to have the thickness and all other properties.
The weight of a 600x600x2 mm was approx. 5 kg and that was a warning. I expected that if I added the aluminum rule, the material properties would be that of aluminum.
Is it possible that the sheet metal rule doesn't add material properties? If so, could you please automate that?
This current setting is totally counter-intuitive and possible cause of very big issues.
Best regards,
Dean
