Announcements
Sheet metal flat pattern not updating after changes in drawing
PaulfCXD94
Observer
PaulfCXD94
Observer
Observer
I have two sheet metal parts in which one is a mirror image (one left one right) of the other. I made a slight change in both parts to increase a hole diameter. Both parts show no errors and the flat patterns don't show an updated needed.  One flat pattern reflects the change correctly but the other does not reflect the change.
Found the issue! Somehow I had 2 instances of the component and one was updating the flat pattern and the other was not.
jhackney1972
Please mark you post as solved to take it off the board.
John Hackney, Retired
