Sheet metal flat pattern dimensions
I would like to be able to dimension my flat pattern and print it out on paper so that when i go to the sheet metal brake I know where to make my bends.  I am manually doing the measure command and drawing it on a piece of paper.  I am sure there is a better way. See a sample part bellow
#Newbie
Thank you
YoavFriedlander
Create a drawing - there is an entire environment for that in Fusion 360 - you are going to have lots of fun 🙂 here is a screencast by Nick Ni
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/screencast/Main/Details/420c755...
I watched that link. It didn't appear to add dimensions?
YoavFriedlander
Inside the drawing environment there are all the dimension tools u need 🙂
Thank you that was what I needed to continue.  It worked easier than expected!!
YoavFriedlander
That’s great! I’m happy I could help 🙏🏼
