@andrei8XEXS wrote:
Hi
Thanks a lot for help!
My intention is to create the lateral shape of the competent with 2 lines and an arch (the upper part of the laterals).
I'm not very experience user so if you can detail a little bit what can I do in order not to start all over again, I will be grateful!
Andrei
My guess is when you created the arc you did a click and drag movement rather than clicking one point then the next. With the line tool active if you click and drag from and existing curve Fusion will add an arc. All you need to do is delete the arc then recreate using a line.
To fix, edit the sketch and delete the arc and replace with a line and add a tangent constraint between the line and arc.
The sketch is still not showing as fully constrained because you have a construction line created when the drew the 45° line. One easy fix is just drag the point on the bottom line to the centre line.
Now you should have a padlock on the sketch showing it's fully constrained.
Mark Hughes
Owner, Hughes Tooling
