Sheet Metal Coil Unfold Error!! I'm begging for help!!
creamvintagekr
creamvintagekr
So I am trying to make a sheet metal coil unfold and fusion is having none of it. I know this is achievable as i have seen somebody do it on windows. I am using mac. I wonder if it's a mac only issue. I have also attached the windows version that is without error.
TheCADWhisperer
Also, can you provide the link to the Windows example?
These references will save time in diagnosis.
I am sure this has nothing to do with Mac or Windows OS.
creamvintagekr
I just found out the problem. There seems to be a relationship between the angle of the coil and the number of rotations with associated limitations. What these are exactly I don't know but with a bit of tinkering you'll find a combo that works.
TheCADWhisperer
Nope!
