I have been trying to form a bend on a sheet metal object across a short 9mm line, however it appears that Fusion 360 is bending the entire side of the object when I select this 9mm line. I attached a photo to show this. I just want the object to only bend across the 9mm line and tear on the sides of the bend. How can I do this? I can't find any solution. Overriding relief rules does not do anything (since there is no relief).
Any help would be greatly appreciated
Thank you very much
