Sheet 1 and sheet 2 title blocks
ldhetrick7
ldhetrick7
When I add a second sheet to my drawing the correct sheet 2 title block is present, however, it changes sheet 1 title block to the sheet 2 title block. Changing sheet 1 title block back to what it should be also changes the title block on sheet 2.
I also find any changes I make to the title block on either sheet is reflected on all sheets. Subsequent drawing sheets have always had a streamlined title block (not a duplicate of sheet 1).
ClintBrown3D
Hi @ldhetrick7
I’m sorry to hear that you are having trouble. I’d like the team to take a closer look for you. Please share a downloadable link to your 2D drawing, so that I can ask the team to investigate this, or if it is sensitive, feel free to send it directly to me Clint. Brown {a} Autodesk.com
cc: @Pramod.kadam @-KyleWilliams-
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
ldhetrick7
https://a360.co/3KKpUVM
Hope this helps, I can send my templates if you need them, but the sample templates do the same thing.
g-andresen
In several attempts I have been able to assign the title block individually for each worksheet
OS : W10
günther
ldhetrick7
How did you do it? I've been trying for months with no luck. Everytime I
change the title block on one sheet it changes all the sheets.
Les Hetrick
ClintBrown3D
If you have multiple drawings borders set up, you can choose which one goes on a sheet.
Clint Brown
