Announcements
Shaded with visual edges only keyboard shortcut not working
The shortcut CTRL+6 does not work. All other shortcuts for Visual Style works, from CTRL+4 to CTRL+9, except CTRL+6, wich is the one that I use most.
Is it a Fusion bug or something in my machine?
  • bug
jhackney1972
It must be only on your system, works here OK.  Have you restarted the application?  You of course should still be able to use the menu command to switch to Shaded with Visible Edges Only.
John Hackney, Retired
Thanks for your reply. It is a long time bug (more than 1 year) that now I decided to go find a solution. yes, If I click it works, only the keyborad shortcut does not work...
jeff_strater
also works for me, on a Mac, at least (see screencast).  If only one works, is it possible that you assigned that key to another function?  In the screencast, I run through the hotkeys, from CTRL-4 up to CTRL-9, and back down again, stopping at CTRL-6.
Jeff Strater
Engineering Director
I found out the solution! It is a fusion bug. I both my computers CTRL+6 does not work in fusion, but works in other programs. Reading more I found that I need to set my keyboar to US when using fusion. All my computers are Brazilian Keyboard.
