Shaded with Hidden Lines NOT shows hidden lines
Natranzow
Message 1 of 8
Natranzow
Shaded With No Hidden Lines shows exactly the same as Shaded With Hidden Lines. This a bug or am i missing something?Some of the bodies are solid but some are not. This is all regardless of opacity.
Replies (7)
Message 2 of 8
jhackney1972
I want to be clear, you are talking about in the 2D drawing?  Also could you attach the model exhibiting this issue.
John Hackney, Retired
Message 3 of 8
jhackney1972
I will assume it is in the 2D drawing.  Below is a test of a simple assembly.  I do not see an issue.
Message 4 of 8
jhackney1972
Here is a single component drawing with the same two views.
Message 5 of 8
Natranzow
No. This is for a solid model.
Message 6 of 8
g-andresen
maybe your situation is the same as here.
günther
Message 7 of 8
Natranzow
That seems to be a different scenario. I basically can not get fusion to show me a solid part.
Message 8 of 8
Natranzow
Fusion shows me hidden edges regardless if I select with or without.
