Announcements
Setting coincidence for point on ellipse crashes Fusion 360
r.moss
r.moss
This is a reproducible bug - after it happened twice in quick succession I did a screencast.  Since then it's happened twice more as I try to find ways around it.
I am trying to draw an ellipse to match measured dimensions on a plastic bucket (spoon) for a turbine.  I could not set these as driving dimensions (my first sketch attempt) because the sketch fails to solve.  So now I've started again (Sketch 2) with a simpler layout and I am trying to draw some construction lines.  The construction line that closes the triangle should run between the tangent points.  For some reason it didn't, so I then tried to make the points coincident.  This crashed F360.
PS.  You may spot that I didn't trim the left-hand construction line right back to the tangent point, as intended...I know!
wmhazzard
It's not clear to me what you want to do.
Is this what you are trying to do?
r.moss
Oh dear, yet again the screencast hasn't uploaded to the forum.  This problem seems to have been around for years!  I tried selecting my screencast but then the web page said Invalid html so I attached a link to it instead, which doesn't seem to have worked either.
After about 15 attempts, I have managed to make a sketch that works.  I just have to be careful not to change some of the dimensions as I know it will crash - I must have seen 8-10 crashes today.  My original post was trying to make the blue selected line run between the two intersection points for the 30 degree construction lines and the ellipse.
I really wish there was some way of commenting sketch lines (a speech bubble or pop-up tooltip?) and/or colour coding them so that I can document the sketch and know which line is which when I come back to it in a few years' time.
It's an estimate of the cross-section through one half of a Pelton bucket.
