Set side of a tangent constraint
Trying to create a parametric design of a metal bender (the idea is to have fusion compute the height setting of the mobile roll for a particular bending radius), I faced an issue I can't quite solve. Not that it's really surprising, since I'm not very proficient with Fusion, but still...)
On this sketch, the big circle is the metal piece being bent (thickness : 40mm, diameter parameter set to 920mm) and the 3 smaller circles are the bender rolls.
The inner side of metal piece is set to be tangent to the upper roll, while the outer side is tangent to the 2 lower rolls. So far so good...
But if I set the bending radius to a smaller value (say 200mm, for a 400mm circle diameter), i get this:
Of course, the constraints are still respected, since the center (previously upper) roll is still tangent to the inner side of the metal piece, but it's now on the wrong side of it...
--> Question: how can I specify to Fusion that the tangent relationship should not "switch sides" ?
Thanks in advance for your help,
Stan
