Announcements
Set shortcut for Finish Sketch
jonshoap
Community Visitor
jonshoap
Community Visitor
Community Visitor
I’m setting up shortcuts for my most used commands in Fusion 360, but I can’t figure out how to set a hotkey to activate the “Finish Sketch” function. I saw in several forum posts that this should be an option, but I don’t see any way to set the shortcut in my workspace.
Thanks in advance!
danioan.nestor
You can assign finish sketch to the shortcut panel which you open by pressing 's' (if you have the default keybinding). Then, you can search for finish sketch and you can click on the little arrow icon in order to put it on the bar above so every time you press 's' you can just click on the finish sketch and that is as close as I've come to a finish sketch shortcut. Help 13.png
davebYYPCU
Makes no sense to me.
There are two buttons in the sketch window to choose from, but you want to type s, to find the 3rd button.  (When set up)
When done sketching, Right Click, you receive a menu of next available steps.
If Extrude is in this menu, and it’s the one you need, you don’t have to use finish sketch, just select your next option.
Might help...
