Fusion Support
Server Verification Warning problem - how to solve it??
0 REPLIES 0
Message 1 of 1
223 Views, 0 Replies
Hi everyone,
Before creating this post I looked all of solutions for this problem in this forum.
I am using Windows 10 x64 operation system. Yesterday I faced with this problem and I can't know how to solve it.
I have no problem with Sign In you can see it in attached photos. All problem starting after Sign In process. After these two messages, the application closes. I can't do something.
1. I don't use a proxy.
2. I only use the ESET Internet Security firewall and checked the logs, everything is clear, I did not detect the blocking of the Internet connection by the firewall.
3. 3 times I reinstalled the Fusion 360 clearly.
4. I tried to delete the NMachineSpecificOptions.xml and LoginState.xml files.
All these actions did not provide a solution for my problem.
Analyzes of the WebServices.log file did not give any results there everything is clean. I can send it to you.
0 REPLIES 0
Technology Administrators
