September 2022 Product Update - What's New
In this product update, we've made 72 improvements and fixes based on your forum posts, direct messages, and interactions with our support team. Here is a summary of what we fixed in this update.
General
- Crash when opening and closing a specific design and then closing Fusion 360.
- Save As STL with One File Per Body option produced double STL exported files.
Modeling
- Sweep created faces with duplicated tags.
- Crash without CERs when Fillet option was selected.
- Crash without CERs after clicking OK on Extrude or Revolve.
- Revolve preview was different from actual result.
- Revolve about an axis that is not in the sketch plane incorrectly projected to the plane.
- Selecting multiple edges to create a flange doesn't create it on all the edges.
- [Windows Only] Alt key did not work properly when using Edit Form tool.
- Unable to create patch on a specific design.
- Adjusting a pattern failed due to a hole being out-of-date.
- model crashed while computing Pattern on Path.
- Align command performing slow on certain designs.
- Going from Direct Modeling to Parametric Modeling converted very slow with a model has large number of occurrences.
- When direct-editing a mesh body in Mesh environment, the viewports incorrectly disappeared.
- Look-At for joint origin did not respond to adjustments to the coordinate system.
- Joint preview was correct, but component flipped incorrectly when clicking OK to commit the action.
- Edit joint takes longer than expected to launch its command dialog.
Sketching
- When a sketch was edited, Fusion 360 was slow at computing all the features and finish the sketch.
- Arc flipping on arc tangent to spline and its offset.
- Sketch flipping on parameter change.
- Crash when dimensioning a spline.
Electronics
- Unable to open a specific schematic file.
- Push to 3D PCB was missing a section of copper.
Simulation
- Failed static stress analysis on a specific file.
- Fusion 360 incorrectly rounded up strain values when exported Nonlinear Plastic Plot in CSV and XML.
- Pre-check was inaccurate when bodies were replaced by Point Mass (Auto).
Drawing
- Drawing resolution was poor on macOS machines.
API
- Not being able to create a particular ruled surface when using the API.
- Problem with custom graphics text and positioning relative to the view.
Manufacture
- Not all strategies and setups were listed after Fusion 360 July 2022 update.
- Square insert groove tools: show "use opposite edge" parameter for "tip center" compensation point.
- Rest machining profile roughing gave an unexpected error.
- Unusual gaps in Steep and Shallow where found when using Avoid surfaces.
- Ramp toolpath and Tapered Endmill resulted in a CAM Simulation crash.
- Machine Simulation did not simulate the full toolpath.
- Engrave toolpath incorrectly cut straight through the model – now there is a warning before it happens.
- Random lines form in the infill, crossing already printed lines in Additive manufacturing.
- Heights did not respected entered parameters in Drill operation.
- Ramps containing wrong small piece caused a big arc in toolpath preview.
- 3D Morph Spiral did not respect "Additional Offset" around full perimeter of part.
- Swarf ignored the model and cut right through it.
- Corner clearing cut in engraving was wrong.
- Fusion created wrong toolpath on '2D Pocket' for a specific model with a specific set of configurations.
- (Windows only) "Unable to export library" when exporting a tool library in csv format to folders with non-ascii characters from Fusion 360.
- Crash on editing a particular NC Program.
- Added "don't show this again" checkbox for "different tool has same tool number" prompt.
- NC Program: Post properties got unexpectedly reset.
