Selecting Splines
Selecting Splines
adamw.14128
Selecting Splines
adamw.14128
When a spline Is created with the anchor points is there a way of selecting the line in-between any 2 anchorpoints so I can create a sweep. I still want the curvature data from the other points as removing other points changes the curve. The chain selection does not seem to apply to specific points along a line so I'm at a loss as what to do.
jhackney1972
I hope I am interrupting your question correctly.  I consider the spline you are referring to is a Fit Point Spline.  You want to place a sweep between certain sections of the spline but not all of it.  In the Screencast I did this.  If you want to have two sweep segments, create other work planes and do the same process.
John Hackney, Retired
adamw.14128
Thanks you for putting time into replying to my question! I probably didn't explain my question all that well because I'm trying to describe how I can quantify the 2 end location points along the spline curve when sweeping (not just the ratio between 1 and 0). I was wondering if I could potentially use references similar to the extrude to object when extruding (like when you can select a face for it to extrude exactly to the face clicked). So in your video I was wondering if I could have the end locations of the sweep to be on any 2 of the black vertices along the spline.
