Select faces by one click
nhat_tran64DV2
nhat_tran64DV2
I want to fill the hole in this position by delete command.
But I have to select 25 faces by 25 clicks on the correspond face.
Is there any way to select these face with only 1 click ?
Could you please guide me how to do it
jeff_strater
one click?  No.  How would the software know what faces you wanted to select?
However, you should familiarize yourself will the different selection tools and modes:
because one of those modes will probably make the task easier.  Here are links to some documentation:
Jeff Strater
Engineering Director
nhat_tran64DV2
As some other design software, it allow me to select many face by the option as tangent face with the angle degree.
Can Fusion also has the selection like this ?
HughesTooling
Try enabling the simplify tools in preferences and try out the remove faces tool. Note these only work with history enabled unfortunately.
Only need to select the bottom face to delete the whole pocket.
Mark Hughes
Owner, Hughes Tooling
