Select Body Priority is stuck ON (cannot select faces, edges, sketches, ...)
GillesJrBisson
GillesJrBisson
Hi all,
I am experiencing a new behaviour today which I assume may be a bug related to the recent update.
I am not able to select faces, edges, sketches, etc. anymore. It is as if the "Select Body Priority" is stuck in the ON position.
Normally, I turn on "Select Body Priority" (which I have pinned to my toolbar) when I need to select entire bodies. Then, when done, I turn it OFF to resume normal faces, edges, sketches, etc. selection. This somehow stopped working now.
Has something changed ? Is this a bug ?
Thanks !
HughesTooling
Works fine for me. What do you see if you go to the selection filter dialog? Edit, Have you closed and restarted Fusion to see if a restart fixes it?
Mark
Also, Please don't attach pictures. There's an option Photos on the editor toolbar to embed them, please use this option.
Mark Hughes
Owner, Hughes Tooling
GillesJrBisson
Thanks for your answer.
I do recall that restarting the app did not fix the issue but rebooting my computer (strangely enough) did solve it.
I also recall that most items in the selection filter list were indeed NOT selected. But because I never mess with them, I didn't pay much attention. I guess that is what was causing the problem. Do you know of any action I might have done that would automatically turn most of them off ?
Gilles
davebYYPCU
Well it is written in the title,
if you use this list it overrides Marks list.
