Announcements
Segmented chamfers
Peevs
Observer
Segmented chamfers
Peevs
Observer
Observer
I'm trying to work out the easiest way to create some extra support on the pictured corner with some segmented chamfers/braces.
Is there an easier way than creating a separate body, rotating for the correct angle and just pasting a bunch of them?
seth.madore
Sketch, (turn on "Slice")  create your chamfer, extrude. Create some offset planes and extrude from that surface, repeat as needed?
Seth Madore
Peevs
Observer
Observer
Thanks Seth!
I played with the chamfer tool in the sketch but after being introduced to the slice feature, it was plain I could draw along the faces and match them to make the chamfer. Followed this up with a pattern along path.
THANKS!
