Announcements
Section analysis in drawing workspace
simonhoyland
simonhoyland
Hi.
I had previously added section analysis (not section view) to the drawing workspace, see pic. However, I cannot repeat this action, it won't let me. Can you explain how I can do this please?
Rafal.Chlod
Autodesk Support
Autodesk Support
Hi @simonhoyland, thanks for posting.
As far as I know, there is no possibility to put a section analysis into a drawing in the way that you show on your screenshot. One workaround for this could be to create a screenshot of a section analysis and just insert it as a picture but I think it won't be possible to put it together with its isometric sketch just as you did. There is also a similar forum thread for that topic.
You can also create a section view with the shaded option enabled (which looks more or less like a section analysis) but you mentioned that you don't want to use it.
If my answer helped you, please click Accept Solution. Thanks!
Rafał Chłód
Global Product Support
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
simonhoyland
Hi Rafal,
Very strange isn't it?! In the design workspace I selected Drawing - from design, and sent the 'full assembly' to my Drawing. It displayed as a complete, isometric shaded diagram (NE perspective). When I un-hid Section Analysis in the Design bench and clicked the chain link to update the drawing, I got the section analysis in my drawing as per the screen shot I sent. This is exactly what I needed. However when I modified the design and tried the process again I could not get the section analysis view to transfer to the drawing workbench. I do note that various posters (including yourself) on the forums state that this is not possible - but clearly it is!
I would love to be able to repeat this action as it's something I would find very useful. The Section view does not provide quite the same level of detail I require and importing a screen shot will of course not update when I modify the drawing.
Any further investigation or info would be greatly appreciated.
Simon
ClintBrown3D
Hi @simonhoyland
To get something similar, I would create a shaded isometric projection from a section view.
Clint Brown
Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
simonhoyland
Thank you @ClintBrown3D, that’s very helpful.
