Search and Refresh not clickable in the Data Panel
Bjanders
Bjanders
The Search and Refresh buttons don't react in the Data Panel. Then when I restart Fusion, they work again. Then after some time when I have had Fusion open they stop reacting again. Am I doing something wrong?
I also had a lot of projects missing from my folders, which reappeared when I restarted Fusion. I really got scared for a moment that I had lost some of my work.
Edit: Even restarting Fusion does not help now, and I can't access some of my projects. It just shows the spinning image over the project, and it does not open. My network is working, and I just had that specific project opened two hours ago, so it should be cached anyway.
Edit 2: I went to offline mode and I and was then able to open it.
Replies (12)
yugesh_mahure
Thanks for sharing feedback.
If you are still facing this issue can you please share your diagnostic log files to help our team diagnose this issue further?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-and-sh...
Also please check if you are able to open/view these projects from "Open" dialog.
Yugesh Mahure
Bjanders
This happened again now. It also shows "Content last refreshed: Never", which is not true.
Opening a file via the "Open..." dialog works.
I collected the diagnostics. How do I deliver it to the Fusion team?
Edit: Going to offline and then directly back online resolved the issue.
eerier_bleach0f
Same issue as OP.
Fusion kept crashing over and over again (I need to get some work done).
Eventually the file I needed to work on wasn't openable because it had a blue spinning loading wheel and the search/refresh buttons where greyed out.
Luckily restarting Fusion fixed the issue.
Until restarting won't like with OP and I won't be able to get any work done.
So hopefully we hire some bug testers instead of relying on unpaid hobbyists. And also stop rushing every new feature out. I pay to use this software not twiddle my thumbs while I pray it'll work
Logs attached
Autodesk's most dedicated bug reporter: https://forums.autodesk.com/t5/user/viewprofilepage/user-id/15188348
eerier_bleach0f
Drag/drop it here to upload the diagnostic files:
Bjanders
I know how to attach files here in the forum discussions, but I don't want to upload diagnostics files for everybody to read without knowing what they contain, and I don't want to use time to investigate what they contain.
chrisQX8DX
i have the same issue, most of my projects folders are empty in the data panel, content refreshed say never and search and refresh buttons are inactive. with file>open i can see they are still there .. what's going on ???
Intel Macos 15.1.1
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. Whenever needed or whenever i can i will attach a file for troubleshooting. If no file is attached i will always try to explain as clearly as possible and if needed or helpfull provide illustrative screenshots. When i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
MartinMajewski
Same issue here. Sometimes, search and refresh work after a restart of Fusion, but oftentimes, the data panel is unusable!
Fusion 2.0.19215 arm64 [Native]
Active Plan: Subscription
macOS 14.5 (23F79) on Mac15,10
joshua_sniffen
Thank you. Going Offline Mode and then back also fixed for me. Restarting software and computer didn't help and I was going insane.
FrodoLoggins
This would happen intermittently the past 6 years but only got bad a week or two ago. I don't think restarting Fusion would help. Just toggled offline mode and that's fixed it so far. Logs attached.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
FrodoLoggins
Well that didn't last long. Can't open a file I just uploaded because the refresh button is greyed out
Switching online mode works but then I just get this:
FrodoLoggins
Again. What a joke
gus.grubba
Same here. Switching to offline and back to online makes it work.
