Announcements
screencast embedding impossible
g-andresen
Consultant Consultant
Message 1 of 42
g-andresen
for more than 4 months now i am annoyed with the upload of screencasts.
After a contribution from @TrippyLighting  I switched to use the EMBED option.
Unfortunately it only worked randomly from the beginning and required several attempts.
Since 3 months nothing works anymore and I get error messages.
no embeddingno embedding
So I had to go again the old (stony) way, which lets however increasingly my readiness Screencasts to provide tend towards zero.
I tried with Chrome and Firefox.
I ask you to eliminate this deficiency.
günther
Replies (41)
Message 2 of 42
HughesTooling
Just testing to see if I can embed one of your screencasts.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 42
HughesTooling
Well that worked first time and I've not had any problems using the HTML editor option so don't know what to suggest. I'm using chrome on Win8.1.
Mark
Mark Hughes
Message 4 of 42
TrippyLighting
I've used the HTML method for years and it hasn't failed a single time.
I usually use Safari and Google Chrome, on macOS.
Message 5 of 42
g-andresen
@HughesTooling  & @TrippyLighting  & ??
I tried another (Windows) user account without success.
The error message obviously comes from the forum software.
You can't remove it to try again.
If I press the "Cancel" button to restart, the whole content is gone and a reload is not possible with a new reply.
Should I stop my forum activities now?
günther
Message 6 of 42
jeff_strater
@g-andresen - you should try also posting this here:  https://forums.autodesk.com/t5/screencast-forum/bd-p/58 , the Screencast forum.
I've had mostly good luck with using the UI for embedding screencasts in forums.  Occasionally, one will fail to load, but mostly it works.  I've been told not to try to use the manual embedding (editing HTML), because they screen that pretty carefully, trying to eliminate security risks.  In fact, at one point I was told that editing the HTML was going to be blocked completely for security reasons.
Jeff Strater
Engineering Director
Message 7 of 42
jeff_strater
also, this screencast seemed to post OK for you:  how did you do that one?  performance-issue-editing-sketch-very-slow
Jeff Strater
Message 8 of 42
g-andresen
Hi Jeff,
1. Thanks, Done!
2.
Currently, I can only attach screencasts in the "normal" way, but with the risk that I need up to 5 attempts and a subsequent editing would remove the screencast again.
günther
Message 9 of 42
HughesTooling
@g-andresen  You might want to post in the community forum about the problem pasting HTML into the editor.
Mark
Mark Hughes
Message 10 of 42
g-andresen
Hi Mark,
Mark
Just done (SC-Forum too)
günther
Message 11 of 42
Discussion_Admin
The Screencast issue and a html warnings are two different things
We only allow simple html in the forums for security reasons.
We  currently have a known issue with editing Screencasts. We believe to a fix for this that we are testing now.
Until then do not edit a post with a Screencast. Simply reply and note your correction
DA
Message 12 of 42
g-andresen
the (faulty ) html was generated by the dashboard and inserted without further changes.
looking forward to a solution
günther
Message 13 of 42
__thomas__
The same issue when trying to insert this screencast:
https://autode.sk/2PUuqEL
Message 14 of 42
TrippyLighting
Embedding (not Inserting) functions fine...
Message 15 of 42
jeff_strater
what I've found is that if you are replying to a post where there is an attached file, the embed screencast UI disappears.  So, what I usually do is: post the link to the screencast, then reply to myself with the embedded version.  It's a pain, but it does work.
Jeff Strater
Message 16 of 42
Discussion_Admin
Jeff is correct this is know issue we are working on
DA
Message 17 of 42
__thomas__
Just to check:
I am now replying to Jeff's post, wich has no attached file.
I go to My Dashboard / MY CONTRIBUTIONS and copy the embeded Link "Get embed Code", the following one, correct?
<iframe
                    width="640"
                    height="620"
                    src="https://screencast.autodesk.com/Embed/Timeline/e47215c5-0511-4bba-a2c0-291df2489cd9" frameborder="0"
                    allowfullscreen webkitallowfullscreen></iframe>
Now I try to insert the HTML source code in this post . The preview yields to an "invalid html" error ..
>Your post has been changed because invalid HTML was found in the message body.
>The invalid HTML has been removed. Please review the message and submit the message when you are satisfied.
So the issue seems not to be related to the fact, that one replies to a post with an attached file. And the method of embeding also does not work for me ..
Message 18 of 42
HughesTooling
Seems to embed for me!
Mark
Mark Hughes
Message 19 of 42
g-andresen
This is identical with my contribution # 1!
Embedding test:
as usual without success
I have tried it with different WIN systems, Mac and IOS without success
günther
This is how the experiment went.
Message 20 of 42
g-andresen
Hi Mark,
You (and others) have reported several times that the embed function works for you. Although I have shared this information with the board software on several PCs and Macs, the software was not willing (or able) to do the service. I have provided extensive information about the embed procedure.
I therefore ask you to keep hints that it works for you to yourself as they do not contribute to a positive development.
günther
