Jeff, in your previous post you mentioned that less than 1.0E-06" misalignment between features will not fail joints.
That is not true!
There must NOT be any misalignment between joints (Delta X, Delta Y or Delta Z must be 0 as required).
If somebody is running into issues with the joints because the of extremely small difference between features measurements (as seen in the picture) you can fix it in 2 ways:
1. Click and copy the misalignment value (in this case Delta Z), go back to the sketch and add or subtract the copied amount to the feature you need to move. Because the value is very small you will not see any differences in the sketch. However if you done it properly, when you go back to assembly, this time the features will be perfectly lined up and you can make the joint.
2.) Using "Edit in place" project the features that you need from one component to another. Clean the original sketch, create the features again based on the projections and save the component. When you go back to assembly you will see there is no misalignment between the features (Delta X, Delta Y or Delta Z shows 0) and the joint is successful.
In 2016 I have proposed to add "Tolerance" to the Joint window, same as "Measure" window. The reason is that sometimes you want to make a joint that is not very important in term of functionality, instead of spending hours or days to figure out why the joint fails.
If in the last 4 years you got frustrated because how joints work, drop me a note. Together we can maybe convince Fusion to create a better product. Looks like Autodesk start listening to customers only after it receive 2 open letters from important corporations.
