Announcements
Schematic drawing. Whenever I try to place a component, the program exits with an error.
hmW2E4F
Message 1 of 8
hmW2E4F
Replies (7)
Message 2 of 8
g-andresen
Please share a file und show the process in a screencast.
File > export > save as f3d on local drive  > attach it to the post
günther
Message 3 of 8
hmW2E4F
thanks.
I am unable to save anything because it exits with an error,
I found the following message in the error window
VCRUNTIME140.dll
seems to be crashing.
Do you know what it is?
Date/Time: 2023-05-18 18:34:03 +09:00
Application: Fusion360.exe
Error: Access violation - code c0000005 (first/second chance not available)
Crashed module name: VCRUNTIME140.dll
Exception address: 0x00007fffd4fd146c
Exception code: c0000005
Exception flags: 0
Exception parameters: 0, 0
Message 4 of 8
g-andresen
take a look at
günther
Message 5 of 8
hmW2E4F
thank you. I try it.
Message 6 of 8
hmW2E4F
C++ has been re-installed.
I get the following different error
Any hints?
Date/Time: 2023-05-18 20:19:14 +09:00
Crashed module name: D3D12Core.dll
Exception address: 0x00007ff8cf70accc
Exception flags: 0
Exception parameters: 0, 18c
Message 7 of 8
hmW2E4F
I am not sure, but it worked.
I have a feeling that the display driver is suspect.
Because,
HELP-SUPPORT-GRAPHIC
GPU driver shows DirectX 9
Why 9 ????
dxdiag shows DirextX 12
My old Dynabook M734 uses intel 4600.
I removed the original Dynabook driver and put in the intel driver.
Now
GPU driver shows DirectX 11.0
I do not know why. As a result, it is working.
Thank you very much.
Message 8 of 8
g-andresen
In the future, you should direct your replies to the post you wish to refer to, rather than using the quick reply to the topic opener.
günther
