Hi folks!
I have a DWG file here, from a third party. I imported it by uploading it, inserted it into a design, and it was wonderful. I added a new component, used some geometry from the DWG import, got ready to do some things with it, and realized my scale was off by 25.4! Oof.
I realize this is because the DWG file was generated without something set, and there's no way to tell the online converter that it's in inches.
I have found a bunch of folks with this issue here on the forum (https://forums.autodesk.com/t5/fusion-360-support/dwg-import-into-f360-and-wrong-scale/m-p/8830434 for example) but it seems like they all have AutoCAD. I don't, and it is not really possible for me to get the creator to recreate this file or make edits.
I'm assuming I couldn't fix the unitless aspect of the file without the source.
Can I scale it as a DWG using a tool outside of Fusion360?
