scale up multiple objects
I have a feeling this is an easy action but my head is just not finding it. I have a 3d logo that I now realize I drew way to small. Since it was just a concept drawing, I haven't constrained much. Can I grab everything I've drawn and resize it?
I've attached f3d in case it helps.
g-andresen
Yes!
günther
davebYYPCU
Sort of,  @g-andresen has not done the sketches, depends on what you need,
Fusion's scale routines do not allow you to select the anchor point, as part of the objects to scale.
With that said, you are lucky (or not) that the sketches are not attached or constrained to the origin.
One sketch at a time, Edit Sketch, then Modify > Sketch Scale
Select all the articles you drew, then select document origin as the anchor, add scale factor.
When done the bodies update.
Might help....
