Announcements
Scale entire sketch at first dimension BUG.
HughesTooling
HughesTooling
I noticed if the first dimension is a diameter dimension the scale fails. Doesn't matter if you use a centre line or pick diameter dimension from the right click menu. Screencast shows the problem.
Mark
Mark Hughes
Owner, Hughes Tooling
jeff_strater
yeah, reported here:  scale-entire-sketch-not-working-when-drawing-with-a-quot
The bug has been fixed, and should make its way to an update soon
Jeff Strater
Engineering Director
