Hi @pghmullen126,
Sorry to see that you're facing this problem. This looks like a bug and should get latest updates.
Do you mind sending up the complete log files?
Help -> Support & Diagnostics ->Diagnostics log files. This will generate a zip file that you can upload.
Would you be able to invite me (Sujay<dot>dsouza<at>autodesk<dot>com) to that project?
That'll help us investigate the issue and see if there can be any workaround possible in the meantime.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza SQA Manager
Quality Assurance
Autodesk, Inc.
