Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Saving Drawing Document Settings
4 REPLIES 4
joshua_fynn.wadenpohl
145 Views, 4 Replies
I searched and couldn't find any advice on this issue.
I want to edit the document settings for the drawing of a part (such as line width, arrow heads etc.). Is there any way to save these settings or setting them as a standard to have them in all drawings?
Thanks in advance
Labels (2)
4 REPLIES 4
You can save all your Drawing Document setting by creating a Drawing Template.  If you then start your drawing using this template you will have the settings repeated.  The only thing is the creation of a Drawing Template can only be done using a Fusion Subscription License.  Even it you have someone create one for you, it still cannot be used without having a Subscription License.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Thanks for the help! It worked (most of it)!
One last question since that did not work.
I inserted an image to the drawing template something like a logo and placed it in the area box right below but that does not show up in the loaded template when I want to draw something in a built component (but the rest does work, thanks for that!)
Thanks in advance
I do not know what to tell you, as you can see it is easily done as I show in the video.  Be sure you are using a standard graphic format such as JPG or PNG for your image.
John Hackney
Retired
Thanks for taking the time.
Yes, I inserted the image correctly in the template and saved it but (and idk why) it doesn't show up when starting a drawing of a new part.
I tried two image files, one jpg and one png but neither works.
I could screenshot both, the template and the started drawing but its as easy described, haha.
Don't know how I could make it work.
Technology Administrators
