Saving as mesh from top level produces low refinement meshes
I have noticed an issue where if you right click on the top item in the browser and select to save as a mesh, the refinement is much lower than than the refinement selected. The high value exports a low mesh and a low mesh produces a mesh with so little triangles you lose dimensions and details.
If you instead right click on a component with all the bodies in it and select save as mesh you get a much higher quality mesh.
The same model saved from the top has about 3x less triangles than saved from a component.
I have attached some screenshots below so it can be more clear what I am referring to. The top 2 are right clicking on top and saving as mesh and the bottom 2 are saving from component.
save from component
component preview
