I have a colleague and we are working together on a project hosted in my
colleague's personal storage space. I am a member of that project.
We've been doing this for a long time now, without any real problems. Why
we use his project and not a team hub, it is described here:
https://forums.autodesk.com/t5/fusion-360-feedback-hub/open-feedback-on-fusion-team-and-data-managem...A while back Fusion introduced a feature whereby one team member could see
when a file is opened by somebody else. It worked for us for like a week or
so, then it did not. So I have no way of knowing if my colleague "reserved"
a file. I was not warned not to make changes to the file and to the best of
our knowledge I was the only one editing the file(s) from the initial post
here, especially the -M125 one. My colleague may have had at some point the
file without -M125 open but not at the time I was making changes.
Speaking of knowing when the file is reserved: Today, after that "save as
latest dialog showed" (after several repeated app crashes sent to Autodesk)
I suddenly started seeing the file as reserved by my colleague. Even after
he saved and closed the file, and after I was supposedly saving as latest,
nothing happened. No change was uploaded to that file. Its "reserved"
status stayed for a long time and my saves were only made locally.
To be noted that with all these files I tried to save them with another
name, in order to preserve my changes before attempting a local cache
reset. Each time the save attempt failed. A copy would appear to be saved
but in reality nothing would be uploaded and upon refreshing the data panel
the copy would be gone. My colleague may have reserved the initial files,
but he could not reserve the copies I was trying to make.
