Fusion Support
Save to mesh does not correctly persist last used settings if send to 3D print utility is enabled.
0 REPLIES 0
Message 1 of 1
leoblue2002
36 Views, 0 Replies
Save to mesh normal behavior - the last file type you saved as is selected as the file type to save as.
Save to mesh incorrect behavior - When "Send to 3d print utility" is enabled the STL file format is always selected. and becomes selected even if you had already specified a different file format.
This behavior is Wrong because if the tool is capable of remembering what file I used last when i'm not 3d printing it should be capable of remembering what file I used when i'm 3d printing.
This behavior is also wrong because most of the time when i'm using save as mesh i'm exporting multiple bodies to be printed and STL fuses them together.
Save as mesh Correct behavior - It remembers the last file type you saved as when sending to 3d print utility and selects that format.
0 REPLIES 0
