Save "OK" Button does nothing
felix.matzik
Message 1 of 18
felix.matzik
Hello everyone,
I just ran into an odd and frustrating error:
Currently I cannot save my data. When I go to the floppy disk in the upper left corner of the screen a window with the version description opens as usual. If I click on "OK" here, nothing happens (see picture). The file is not saved and the window does not close by itself as usual.
Saving as a new file is possible.
Can anyone help me with this?
Replies (17)
Message 2 of 18
DonBianco
Observer
Observer
The same issue for me. No saving possible.
Using Personal- no commercial edition.
Message 3 of 18
R∀T
Exact same issue here. One shoddy workaround is closing the tab. it autosaves your work.
Message 4 of 18
Same issue.
Message 5 of 18
Same here. Can't save my projects anymore
Another Workaround is to save the project as a new file.
Message 6 of 18
hils.s
Community Visitor
Community Visitor
Exactly the same issue here
Message 7 of 18
Having the same issue. Thought it could be my licence running out, but same issue with both my private and my startup-licence.
Message 8 of 18
Having the same issue. Thought it could be my licence running out, but same issue with both my private and my startup-licence. I thought one of my plugins was the issue. But deinstalling Fusion 360 (with Fusion_360_cleaner from Autodesk) and reinstalling did not help.
Message 9 of 18
g-andresen
@felix.matzik @hils.s @Anonymous @Anonymous
If you skim through yesterday's contributions, you will find various entries with similar content.
Just switch temporarily to the English UI.
günther
Message 10 of 18
this does the trick! Thank you!
Message 11 of 18
t.g.roth
Observer
Observer
Hello Günther,
I have switched the language from German to English and restartet Fusion. With the English language setting the "save" command is working. After a restart of Fusion with German language the problem is back again, no way to save the project with the command "save".
Do mean with to work "temporally" with the English version, as long until a bug fix will be released?
Thomas
Message 12 of 18
felix.matzik
Hi Günther,
thanks for the reply! I changed the user interface to English and the save button seems to work properly again. But as soon as I switch back to German, the same problem occurs again.
Message 13 of 18
t.g.roth
Observer
Observer
Additional to my post:
I think this problem is linked to the update to version 2.0.9439
Message 14 of 18
t.g.roth
Observer
Observer
Addition to my post before:
Message 15 of 18
g-andresen
life is one of the hardest
@t.g.roth wrote:
...  as long until a bug fix will be released?
YES !!!
günther
Message 16 of 18
RajkumarIlanchelian
we apologize for the inconvenience and confusion caused here. Please work on the English UI and we are planning an update in as little as 3 hours from now that will allow you to go back to the German UI.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 17 of 18
RajkumarIlanchelian
Please update to version 2.0.9440 which is now available. You should be able to get back to saving your documents using German UI. Once again we apologize for the inconvenience caused.
Autodesk Fusion
Join Fusion Insider
Message 18 of 18
t.g.roth
Observer
Observer
Hello Rajkumar,
I have updated to version 2.0.9440 and the command "save" with German
settings (UI) is working again.
Thank you for the quick response with the update.
Best regards
Thomas
