Announcements
Save Fila Version
ddeschner
Save Fila Version
ddeschner
I would like to know why Fusion 360 wants to save new versions after each movement of a component. In my assembly I selected the Revolute Joint for some of my components. Well, after I manipulate the components movement the Save Icon highlights prompting to save a new version. Am I applying Revolute Joints incorrectly? Is there a way to avoid saving a components movement as a new version?
Thank you,
Daniel Deschner
Win-Dor Systems LLC.
jeff_strater
Any component movement is a change to the design - whether from the Move Component command, component drag, or some joint exercising.  If you save, then close, those new component positions will be maintained, so it is part of the design state.  If you revert the movement, or undo, the design should not need to be saved.
Jeff Strater
Engineering Director
