Save as GRBL or something else to use in Lightburn software
deonholt
deonholt
Hi all.
Free account and design and 3d print stuff for in and around the house.
I also have a small DIY CNC machine.
I need to replace the aluminium plate onto which the router's bracket attached. But I need the 8 holes to be precise. So, I drew the plate and then carefully designed the two rectangles which corners will serve as markers/guides for the drill bits.
My initial idea was to design everything in F360, export/save it as something and then import that something into Lightburn, the software my 10W laser uses. I will then edge/engrave the 8 x 2mm holes onto the plate to be 100% sure that the holes line up correctly.
I am now at the point where I have saved the design as a STL to 3D print a 3mm thick template for the 8 holes.
Is there something else I can try/do?
Thank you very much.
Warmingup1953
Why not .dxf or .svg?
deonholt
Thank you so much.
I have just exported it as DXF, Wasn't aware that I could.
SVG doesn't show up as an option when I right-click on the sketch. Am I doing it wrong?
Thanks again.
Warmingup1953
Good news!...Yes .svg is available via a free Add-in but .svgs can be problematic with dimensions out not equalling dimensions in.
FWIW:
https://apps.autodesk.com/FUSION/en/Detail/Index?id=3662665235866169729&os=Win64&appLang=en
I also use another free add-in for simply exporting laser-ready .dxfs in the simplest possible way from planar faces of Solid Bodies:
https://apps.autodesk.com/FUSION/en/Detail/Index?id=7634902334100976871&os=Win64&appLang=en
I set kerf to Zero as Lightburn is very good in this regard.
deonholt
Thank you so much for the 2 links. This really made my day. Perfect. 😁
