Announcements
running very slow on every think
Message 1 of 11
so if i load my model or try and do a line in sketch i get not responding. and a coupe of minutes later it comes back to life. it is even worse after the update.
hardware: ryzen 1700 at 4ghz, 16g ddr4, m.2 ssd and radion 5500 xt.
Replies (10)
Message 2 of 11
lance.carocci
@Anonymous, could you please answer a few more questions about this problem?
  • Does this happen with all files, or just a specific one? Does it happen with the same files on other machines?
  • Your device specs are certainly enough - are all drivers up to date? What is the connected display(s), over which port(s)? It might be easiest to include a DxDiag report, but you may wish to remove any potentially personally-identifying information from it before uploading.
  • Does the 4Ghz overclock refer to the base or turbo clock? If this is 4Ghz base, I know that is theoretically possible for the Ryzen 1700, but it's at the high end and is possibly a contributing factor. Do you experience this at base clock speeds and voltages for CPU and RAM?
  • Do you have any gaming audio software or drivers active, something that could potentially mistake Fusion 360 as a game? For example, Nahimic or Asus Sonic Suite. You might try disabling these with Fusion.
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
Message 3 of 11
sorry for late reply. it is a base clock of 4gz and i don't have any software or sound software that is installed. when it dons run slow and don't respond my CPU is not even at 10% and my memory i only at 48%
it is ok on very basic work but when my triangle count gets to high then it starts to do it.
Message 4 of 11
g-andresen
1. please show a part of this behaviour in a screencast.
2. Do you use imported models or sketches?
günther
Message 5 of 11
it is my own sketch. it is at v22
i cant attach the video. its to big. but if i go to delete a face or save it it frizzes and goes in to not reposing.
Message 6 of 11
g-andresen
If you are interested in a solution, please provide the file with relevant information about the problem.
Without this we will stay with the crystal ball.
günther
Message 7 of 11
seth.madore
I would suggest using the ScreenCast utility to record what's going on and then attach the link to it.
https://knowledge.autodesk.com/community/screencast
Seth Madore
Message 8 of 11
https://autode.sk/30wjgv3 hope that helps
Message 9 of 11
and this is the file
Message 10 of 11
lance.carocci
@Anonymous can you tell me more about the initial creation of this file? I see the timeline begins with a base feature containing many sketches, but it is unclear how these were utilized prior to what I see opening v27. What happened to bodies 1-16?
In testing this file I also encountered freezing, even when modifying a single, continuous edge. In checking the callstack, there is a significant amount of assembly-related activity, as if the Fillet is trying to account for extra geometry not visible to the user.
In any case, this gives me enough to start a conversation with some code-facing folks to see if anything stands out, but any additional information about this file would be helpful.
Aside from this, are any other files impacted?
Side note: are you certain that your Ryzen 1700 base clock is 4Ghz out of the box? As far as I know, these chips are 3Ghz base/3.7Ghz turbo. It would be worth checking if there are any utilities in the bios (such as XMP/Extreme Memory Profiles) overclocking automatically, as overclocks have the potential to impact calculation workflows if pushed too far.
Lance Carocci
Message 11 of 11
Morning. Thanks for your help. It was all originated From sketches. I just had to hide the history bar a couple of time.
The CPU is over clocked to 4.05ghz and it runs on that all the time. I have tried it with the standard clocks but no change on it not responding.
