Announcements
Roughing feed rate still using finishing feed rate with multiple roughing passes turned on.
dave.eckblad
dave.eckblad
I've already followed this article here.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Roughing-passes-us...
Can you see anything wrong with my settings or understanding that'd cause the initial roughing passes to use the finishing feed rate? The contour path is a simple 2.5" circle.
Thanks!
daveeckblad_0-1685219120341.pngdaveeckblad_1-1685219155350.pngdaveeckblad_2-1685219175863.png
seth.madore
Sorry for the late reply on this issue, could you share your Fusion file here?
File > Export > save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
dave.eckblad
Sure I can get to that later. I'll add one thing I noticed. It seems this behavior occurs with inside edges of a circle but not outside edges. I have feed optimization angle at 90. I'd think a circle wouldn't trigger that lower feed rate. Does the toolpath log show a different status for feed opt rate versus finishing feed rate?
