Fusion Support
Rotating the view with the ViewCube makes it jump to a random angle
0 REPLIES 0
Message 1 of 1
v_cs
84 Views, 0 Replies
Hello!
I noticed recently that using the ViewCube in the top right to rotate the view (in Design view), after moving it a little, makes the view rotate to a random viewing angle.
This happens when I use Windows 10 at a 125% scaling - and strangely only when I rotate the cube ccw - which makes sense for me because of my bad eyesight and the relatively high DPI monitor I have.
As far as I'm aware, DPI scaling shouldn't affect the software's behavior. Is there anything I can do to fix or work around this issue?
0 REPLIES 0
