Fusion Support
Rotate UX Doesn't Display
3 REPLIES 3
JamieMacL
101 Views, 3 Replies
I'm using an ARM device (if that matters).
If I choose Move/Copy there is no provision to select an axis for Rotation.
UX displays correctly for other operations.  E.g for translate
But for Rotate, I get nothing that allows me to select an axis
Is there any workaround?  A hot key that will select an axis for me?
3 REPLIES 3
HughesTooling
in reply to: JamieMacL
You just need to select something with the mouse pointer like an edge.
Mouse pointer didn't show in the screen grab but all I've done is move the pointer over an edge.
After selection an edge the rest of the UI shows.
Mark Hughes
Owner, Hughes Tooling
JamieMacL
in reply to: HughesTooling
Thanks - what if I wanted to rotate around the center?
HughesTooling
You would need to create an axis where you want to rotate around. This could be from a sketch or created using the construction tools. The free move option does allow you to pick points on surfaces but I would not recommend using free move as it's not parametric.
Mark Hughes
