Announcements
right click and sketch dissappears
osprey75
osprey75
when i right click sketch disssappears and autodesk fusion 360 fills the screen. Done the clean uninstall and reinstall about 5 times with no luck. This didnt start till the fusion update with the new look. fusion 360 flashes on the sceen when i try to move a sketch around. Hard to move sketch when i cant see it. any suggestions? windows 10
Replies (10)
Phil.E
Hi, thanks for posting, glad to help.
It sounds like you haven't updated Fusion 360 for a couple years. Is that true?
Anyway, what you describe are graphics issues. Can you please gather and post your graphics diagnostic info? Go to Help > Support and Diagnostics > Graphics Diagnostic. You can copy the info to clipboard and paste into a reply to me.
Another question, are you using more than one monitor? Please describe your display hardware setup so we can eliminate it as a possible reason for this.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
osprey75
I have the latest vesion of autodesk, cant find the graphics daignosis any where on laptop
Phil.E
The graphics diagnostic is part of the Fusion 360 help menu.
It opens a dialog that has a "copy to clipboard" button.
After you copy the information to clipboard, respond to this post, in your response use Paste to paste the information.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
osprey75
[GPU Information]
GPU Device: AMD Radeon(TM) RX 5600M Series
GPU RAM: 6144 MB
GPU Driver API: DirectX 11.0
GPU Driver Version: 27.20.11018.6002
GPU Driver Date: 09/01/2020
[Graphics Effects Settings]
Anti Aliasing: On
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: Off
Ground Reflection: Off
Selection Display Style: Simple
Transparency Effect: Better Performance
[Limit effects to optimize performance]
Off
Phil.E
Looks like newer drivers are available.
https://www.amd.com/en/support/graphics/amd-radeon-5000m-series/amd-radeon-rx-5000m-series/amd-radeo...
I cannot comment if they will solve the problem, but would be a good place to start. Another thing you could try right away is limiting all graphics effects using the tick-box in the graphics diagnostic.
And I didn't see your answer, are you using more than one monitor? If yes,please describe how your monitors are set up.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
osprey75
sorrry forgot, no just laptop no other monitor
osprey75
osprey75
osprey75
thanks for the help. going to try the driver update
osprey75
