Reversing draft pull direction on surface
Hi Fusion360tanistas!
I am creating a part used for plastic injection molding and got a part scanned and I modified the part to suit my applications. The thing is though, with the methods I used, using existing surfaces to trim out unwanted parts, I ended up with a problem. One of the surfaces has a draft pull direction in the opposite way as the rear bosses.
I am not sure how to go about reversing the taper on the outer ring surface because it is connected to other features and there is no timeline since it originated from an X_T File. BTW What are X_T files? I was also given a STEP file, but the X_T file is easier to work with and allows more modification operations, but is there a way to convert it to a F3D File?
