Announcements
Reproducible crash with Coil tool (project attached)
Hamid_M
Hamid_M
With the attached project open (CoilCrash2):
1. Select SOLID -> CREATE -> Coil
2. (You are asked to "Select the geometry or profile..") Select the top surface of the component
3. (You are asked to "Place center point") Try to select anything including sketch points or curves and note that no point or curve turns blue as you hover above them (don't click the mouse button, just try to select, and note that you can't select any existing geometry and give up)
4. Go to SOLID -> SELECT -> Selection Priority, and notice all menu items are greyed out
5. Go to SOLID -> SELECT -> Selection Filters, and unselect Sketch Curves and observe application crash after 2 or 3 seconds.
Fusion 2.0.19440 arm64 [Native]
macOS 14.5 (23F79) on MacBookPro18,2
jhackney1972
I am using a Windows computer and I do not see any issue.  When you are asked to select the center of the coil, you need to select the projected origin and then you select the profile you want to match to.
John Hackney, Retired
Hamid_M
Hi, I can still recreate the crash, I've attached a video below:
Hamid_M
I've attached a video of the crash
