When I open Fusion, everything opens properly and I am able to see group projects in the browser.
As soon as I click to open a project and the project opens and I can see it in the work area, I am immediately requested to save a file named "18x18.svg". I click on "Cancel" and the dialog box closes and then immediately opens again and this happens several times and finally quits.
This also happen when I make substantial changes to the project or try to save the manually.
This always happens and is very annoying.
I talked to customer support (CaseNo: 20488792)and they thought it had to do with Microsoft Onedrive syncing the files. They suggested that I disable Onedrive syncing, uninstall Fusion and reinstall Fusion without Onedrive syncing being activated.
I uninstalled Fusion 360
I reset my computer
I again verified that Onedrive was not syncing any files
I re-installed Fusion 360 and it opened on my computer
I verified that Fusion 360 is not installing on Onedrive
I opened a project in Fusion 360 and the same “Save as” request for the same file (18x18.svg) came up.
I reactivated Onedrive syncing and Fusion 360 showed up in the "documents" folder on Ondrive.
So this did not fix the problem.
Please help.
