Renew a personal license for Fusion 360 issue
a.polychrome
Message 1 of 15
a.polychrome
my license expires on 06.11.2020. I tried to renew it as it described in the article below. I go all the steps throw and download an installer. But when I login in Fusion360 after 30 minutes it still 06.11.2020.
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
I did small screenshots showing the whole process.
Replies (14)
Message 2 of 15
jhackney1972
Be a bit more patient.  I did it the other day and it took a couple of hours.  It depends on the server load.  After installation, you did restart your computer?
John Hackney, Retired
Message 3 of 15
a.polychrome
I did the renewal process several times, also waiting for half a day.
After I start an installer the message appears, that i have already fusion 360 installed on my computer. Should I completely reinstall fusion 360 to renew the license?
Message 4 of 15
jhackney1972
I did not, all I had to do after following the process you outlined, I rebooted my computer, open Fusion 360 and logged in.  I did this within 10 minutes of the process and the new personal license did not show up.  I logged off, waited a couple of hours, opened Fusion 360 logging in during the process and the license was renewed.  You can do it if you like but be sure you do a Manual Clean Uninstall according to this website.  You must have hidden folders showing to do a proper job.  I am using Windows 10, you did not mention your operating system.
Message 5 of 15
a.polychrome
I did all what you've written except Manual Clean Uninstall, logging of, waiting the whole night, rebooting, logging on, it didn't help. I have windows 10 also.
Message 6 of 15
g-andresen
this may be necessary if the automatic uninstall is not sufficient.
If not, try this:
create a new Windows user and install Fusion for this user with your "old" Fusion account.
günther
Message 7 of 15
a.polychrome
I did that, create a new windows user, installed fusion 360 under a new windows user, logged in with an old account. It doesn't work. I think the problem is not my local installation but the servers from autodesk. Something there is not working.
Message 8 of 15
im facing the same issue with you too. been trying for few days. is there any other way to solve this problem?
Message 9 of 15
a.polychrome
I wrote in the support  chat two times. First time they wrote i have to try again 1 week before my license expires, second time they wrote that they guess i have to try only after my license expires.
Message 10 of 15
r.augusiewicz
Hello! I will post in this thread instead of creating the same. I can't extend my personal use license. I did every step thats in the manual - I downalod new Fusion, try to install it but quit when the message tells me I already have it. Waited for more than 24h, did several reboots etc.
Nothing works.
Cmon, it can't be that complicated 🙂
Message 11 of 15
a.polychrome
Did you try to chat with the support? interesting what they will write.
Message 12 of 15
i did try the live chat support. Apparently we only can renew the personal license after its expires. hopefully its true.
Message 13 of 15
a.polychrome
Yesterday there was an update in that article
Note: You cannot renew a Personal Use license until the current one has fully expired. To check the expiration date, check About dialog from the Help menu in Fusion 360.
Message 14 of 15
a.polychrome
I was waiting till today, and now my license expired. When I try to renew it, at the very last step, when I click download and get an error "Something went wrong when creating your hobbyist license."
Message 15 of 15
a.polychrome
Update:
I've tried many times and then the error was gone, download started, and my license was updated!
